Gauge cluster not working, now with video!
Easy,
1.Plug your coding plug IN
2. install the two 7mm nuts behind the gas and temp gauge
3. reset your service interval via diagnostic plugOwner - Bavarian Restoration
BMW and European Electronics Repair and Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
Follow our Instagram!
In the video I can see the receptacle for a coding plug, you will need to use one for your 91.Owner - Bavarian Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
I do have the coding plug (from the old cluster) but I don't think it's going to work. Here's what I mean:
As you can see (hopefully the picture shows enough detail) there's just nothing back there. The plug was actually covered with a piece of plastic that I broke off, (you can still see the tabs that I broke it off of) leading me to think there's never been a coding plug in this thing.
I also don't see any 7mms on the back of the cluster. Did I just happen to pull out a really weird cluster?
And there's no 7mm nuts because they are missing. They attached to the back threaded stud of the temp and fuel gauge. Those are the ground studs, and without a ground, they will go full red/full.Owner - Bavarian Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
This is the plug socket for the 1982-1986 clusters. The 1986-1992 clusters have the coding plug in front.
www.BavRest.com
My Feedback Thread
Our Facebook!
Okay, very good information as always guys. So from this I can conclude that my car has had the cluster replaced previously, since the VDO that I pulled out was using the older coding plug.
In this case, I don't have a coding plug. Somebody must have pulled it at the JY before I got there. I'll also need to find those bolts somewhere. Off to eBay.
Originally posted by mikeb23ft View PostOkay, very good information as always guys. So from this I can conclude that my car has had the cluster replaced previously, since the VDO that I pulled out was using the older coding plug.
In this case, I don't have a coding plug. Somebody must have pulled it at the JY before I got there. I'll also need to find those bolts somewhere. Off to eBay.Owner - Bavarian Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
