Central lock system doesn't operate the trunk lock
  • emi
    • Jun 2005
    • 80
    I noticed that the central locks in both my e30's don't operate the trunk lock. The lock is functional, I can lock and unlock the car from the trunk, but not the other way around. To lock or unlock the trunk, i have to do it manually. It doesn't seem right
  • DSchultz325e
    • Aug 2004
    • 1158
    I'm fairly certain it is supposed to be that way.
    I retired my E30 for now...
    E46 323i
    David Schultz
    • Justin B
      Sikky Nar Nar
      • Mar 2005
      • 4273
      Yep, thats correct. My keyless is wired to my trunk lock.
      • Dave
        E30 RAT
        • 11675
        Lock actuator in there may be busted -- or missing.
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
        • emi
          • Jun 2005
          • 80
          wired to the trunk lock, hm... I tried doing that, but the system got confused. It would either only lock, or only unlock. I would have to manually actuate the trunk lock to be able to go the other way... So, instead of doing that, I wired it directly to the driver door inputs on the control unit.
          • emi
            • Jun 2005
            • 80
            It's there, operating the trunk lock using the key, locks and unlocks the door locks, so it's there.
            • emi
              • Jun 2005
              • 80
              That makes no sense, tho. Unless it's a safety thing. If it doesn't lock everything, it should be called a central locking system. It locks the doors and the fuel tank, why wouldn't it lock the trunk. It has an actuator, with 6 or so wires going into it. I think 2 of those are supposed to actuate the lock.
              It would be more clear to me if I spent 2 minutes reading the manual, wouldn't it. lol. thanks for the replies, guys
              • DSchultz325e
                • Aug 2004
                • 1158
                I would assume it is to prevent trunk access without a key. However, it should unlock if you haven't deadlocked it at the trunk (keyhole is vertical). In that case, it requires a key to be physically inserted before it will open.
                I much rather prefer this method because of my stereo in the trunk. This means even if a theif gets your doors unlocked, their only option for getting the trunk unlocked is a crowbar...unless they have the spare key! :)
                E46 323i
                David Schultz
                • Alluvium
                  • Feb 2006
                  • 42
                  :borg:
                  i like the auto trunk lock its great for me, because i have a 12" in the boot in a sealed box, and it the boot is opened while its pumping it will blow the sub...
                  so my radio head only turns on when i turn my key in the ignition, which also locks all my doors and my trunk :) so i cant open the boot when the music is playing ::D
                  • MrK
                    • Jan 2006
                    • 709
                    Originally posted by Alluvium
                    :borg:
                    I've never heard of a sub blowing cuz the trunk was open...
                    This is your M20 on steroids:
                    • Alluvium
                      • Feb 2006
                      • 42
                      basically the closed trunk makes it semi pressured... so the sub does not vibrate back and forth as much if i pop the trunk and turn up the volume the sub coils could burn out... because of all the work its doing trying to be a free flow sub and all
                      • Digitalwave
                        is a poseur
                        • 6280
                        No, the sealed box is what puts pressure on the sub. You won't blow it with the trunk open. When the trunk is open it may not sound is well if you are sitting in the car though.
                        RISING EDGE
                        • DSchultz325e
                          • Aug 2004
                          • 1158
                          Hm...I think you are clipping the crap out of the signal and the only way you can hear it is if you open the trunk and hear the subwoofer distorting heavily. When you close the trunk, you can't hear it nearly as much. Is that the case?
                          E46 323i
                          David Schultz
                          • Alluvium
                            • Feb 2006
                            • 42
                            mm cool thanks, i was always under this mis guided impression : / interseting, still dont want to take too much of a chance.. but ill deff now go read up fully on the pressures that are envoled,
                            ta again :up:
                            • DSchultz325e
                              • Aug 2004
                              • 1158
                              There is no need to read up on anything. It's just fine. Atmospheric pressure is atmospheric pressure...
                              E46 323i
                              David Schultz
