Small backstory:
Car vibrates a good bit due to some rear wheel bearings I've been too lazy to install and needing some suspension work.
Car has been having an intermittent start issue this past week, sometimes the starter whirs and won't start, turning key off & trying again works perfect.
Today I was running a couple errands. Starts perfect runs perfect each time. On my last stop I park for 5 minutes, go to leave and nothing. No power whatsoever, I connect my battery to a spare battery I had in my trunk (my alternator was failing last month) [Also I'm aware it isn't recommended to jump from the battery] The jump did nothing. Take the battery to the front and jump it off the positive power block. Starts fine. Remove the cables and it continues to run. Go to back out of the parking spot and dies (perhaps was pulling enough juice from the battery to maintain idle but not run?)
I'm not in the best area to diagnose further so at this point I say F it and decide to limp the car home (9miles). So I snake my handy dandy supreme 4ga XLong jumper cables from my battery out of the trunk into my rear window, outside my passenger window and under the hood to the firewall block and ground it to the engine hoist ring. Don't worry I keep the trunk/hood stable with some gorilla tape. :pimp:
I'm going over the ground wires now, sanding and such. I've already got an extra cable grounding the engine. It seems to be that the big 00ga power wire has a short in it somewhere.
Has anyone else had to replace their positive battery cable?
