Will engine intereference go away with a new amp/deck?
  • thatphysicsguy
    • Mar 2013
    • 843
    So I have some pretty bad whine in my stereo that is dependent on engine speed. I currently have a 90's vintage sound system in there and I'll be replacing it with a new deck and amp along with a lukebox.
    I pulled out a transformer of some sort that I posted here a couple nights ago and the whine started I think because I pulled it out. Was it some stop-gap solution to cover up the interference?
    Will the whine go away with new things that are less um leaky? or do I need to address some issues with wiring before I install all my new goodies?
    '91 325i
  • bmwman91
    • Oct 2004
    • 3134
    It probably won't go away by just replacing the black boxes. My guesses for the cause are:
    a) Funky ass ground loop issue
    b) If the system is using speaker-level inputs to the existing amp, only the + wire for L and R is hooked up to the amp. You need both + and - connected to a line level converter, or an amp with inputs specifically for + and - speaker level inputs. DO NOT UNDER ANY CIRCUMSTANCES CONNECT A - SPEAKER LEVEL SIGNAL LINE TO GROUND! You'll let the magic smoke out of your head unit and it'll stop working.
    Transaction Feedback: LINK
    • thatphysicsguy
      • Mar 2013
      • 843
      Lol magic smoke, I love that.
      But if I'm putting a new deck and amp combo with +/- speaker level inputs then that should address the problem barring bad ground. Because with the line level converter, I didn't get any of that bad sound
      '91 325i
      • bmwman91
        • Oct 2004
        • 3134
        If you go with a new deck and new amp, and use the + and - inputs you should be fine.
        Your issue arose when you removed the old transformer board thing, right? It looked like it had RCA connectors. What was it hooked up to before, exactly?
        • thatphysicsguy
          • Mar 2013
          • 843
          it was hooked up between the amp inputs and the deck outputs in line with the RCAs that run back.
          from what you say, I'm pretty optimistic it'll go away, thanks!
          '91 325i
          • Hellabad
            • 807
            The best advice I have received, that has worked really well, is this:
            Do not ground the head unit to the chassis. Instead, run the ground all the way back to the same ground as the amp.
            You are probably running new wires anyways. Note: It has to be a fat wire, not a skinny one.
            If starting from scratch, run all of the power wires down one side of the car, and the RCA and speakers down the other side of the car.
            Jay
            Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
            Ground Control Gallery
            The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
            • bmwman91
              • Oct 2004
              • 3134
              Oh, so the existing setup uses RCA outputs from the deck to RCA inputs at the amp? In that case, I am not really sure what the transformer board is, but you could try putting it back. It seems unlikely that it is going to do anything noticeable to sound quality, other than improve it if it eliminates engine noise lol.
              • dustyperez
                • Feb 2012
                • 390
                Jay
                like he said, the best remedy for this is have a good set of rca's and keep them opposite side of the power wire.
                • StereoInstaller1
                  GAS
                  • 22679
                  Your new system is a new 5 channel connected to a new aftermarket deck, right? You will not be using that shitty old LOC, nor any wiring that isn't stock.
                  These days when using new gear, even cheap Taiwan shit, noise is rare.
                  Run 3 pair of nice RCAs up the left side, you likely will not have any noise issues at all.
                  Now GET TO WORK!
                  Luke
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • thatphysicsguy
                    • Mar 2013
                    • 843
                    Now GET TO WORK!
                    Luke
                    Lol luke, you're gonna be the one tackling this next week!
                    I'll send your deposit in the morning!
                    '91 325i
