teh sound of BASS, and my fuel line : / ?
  • Alluvium
    • Feb 2006
    • 42
    ok to start heAr..(har ahr a pun.. : /) is my sound set up
    i have splits in the front, tweeters are dash mounted
    and i have a 1600W 12" in teh boot in a sealed box
    powered off a 1200W amp
    i get alot of bass, my box has space for another 12" if i get bored...
    right i have a convertable, the i went for a crisp sound that didnt rely too mucbh on a solid roof to bounce around off (im picky picky about sound quality, and i notice the diff)
    anyway, i find that when i am playing (i listen to trance, dance, some rock and some hip hop) if i play a tune with a big bass kick, and then say silence , so like "BOOM ... BOOM ... BOOOM" and i am in 2nd gear driveing slow...like idle is 1.5 / 2 then my car jerks, it jerks in a "i need petrol" kind of way, and i am sure my bass is interferring with my petrol line...
    question one, am i right ?
    Q2... if i am, what is actually happening , on the tecknical level ? (im a motor teck noob):pimp:
  • DSchultz325e
    • Aug 2004
    • 1158
    What exact brand/model of subwoofer and amp are they? Does it necessarily have to be 2nd gear? It sounds like voltage drop/severely high current draw, but the information is too vague. If you've got a multimeter and can use it, measure the voltage at the battery during the time when you suspect this problem is supposed to occur. Also, does your battery (charging) light come on at all?
    I retired my E30 for now...
    E46 323i
    David Schultz
    • Alluvium
      • Feb 2006
      • 42
      its not electrical, its deff the fuel line, um i think it might be the replay for the fuel pump, has the power cable runnign over it....
      • StereoInstaller1
        GAS
        • 22679
        I could maybe see the fuel pump starving...but I bet David is right...I bet it is ECU or coil related.
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • wastedincome
          • Aug 2004
          • 906
          A amp that big w/ no power cap.??? Hhhmmmm
          The amp is pulling power away from your other electronics such has ECU, fuel pump, etc
          just my
          Wastedincome420@yahoo.com
          CURRENT STOCK LIST:
          00' e38 750iL HighLine=Highway Queen
          92' e30 318 vert=Aint going anywhere
          91' e34 535iM=Aint going anywhere
          91' e34 525iA=For parts
          92' e34 535iA=For parts
          • Alluvium
            • Feb 2006
            • 42
            power cap ?
            wha is a power cap ?
            • 808BMW
              • 2910
              By the way, what brand + model is your amp? *waits for a 4 channel 1200watt special*
              A power cap(acitor) is supposed to store power for hard bass hits, so that it can dynamically provide power when most needed.
              Otherwise its another drain on already strained system, I personally have never used a cap and never will.
              • DSchultz325e
                • Aug 2004
                • 1158
                He's right. Figure out what is going on, THEN decide how you are going to fix it.
                E46 323i
                David Schultz
                • BMWguy
                  • Jan 2004
                  • 482
                  What guage wire are you using to power and ground the amp... these could also have a LOT to do with power drain? with a 1200w amp you should be using NOTHING smaller than 4 guage but the bigger the better...
                  if that made no sense... you should have two wires coming off the amp that are bigger than the rest... if they dont look like a small water hose then they are TOO small...
                  • DSchultz325e
                    • Aug 2004
                    • 1158
                    Here's a great outline of the fundamentals of typical alternator/battery charging systems, and the use of capacitors and wiring upgrades with their inherent purposes.
                    Checkout the full domain details of Betteraudio.com. Click Buy Now to instantly start the transaction or Make an offer to the seller!
                    E46 323i
                    David Schultz
