Hey guys,
I've got a 318i which I'm fixing up, I've got an issue with the speedo, tacho, clock and radio not working. I bought the car with these issues from the PO, and I believe him saying something along the lines of the radio suddenly not working about 6 months back. The coincidence of these all not working makes me think fuse or SI board - I've taken the cluster out, and need some help!
I really want to narrow down what's causing it; since I can purchase a used working cluster (odo isn't working, should be an easy fix with new gears) but I don't want to if it's a fuse that's gone haywire and the cluster actually works.
I've really got no idea about the wiring, so a detailed diagram with some help as to what to look for would be great!
One more thing, the speedo does work, however it is a little behind as in you'll be driving at 60km/h but the speedo reads 50km/h - I haven't driven it in a while, so it may not be working at all now.
But as mentioned, the clock and antenna do not work, it has an after market radio, and the antenna is up and won't go down obviously.
Thankyou!
Oh and it's probably worth mentioning that this is a different cluster to the one the car originally had, the PO replaced the old dashboard and cluster with the current one.
Thankyou!
