OBC issue
  • Jed the Fred
    • Feb 2013
    • 51
    OBC issue
    Temp shows 22 degrees but I know its a bad temp sensor. AVG MPH and MPG sit at the same number and it won't change. Should I just buy a new OBC? or is it just sensors?
    1991 Convertible (The BathTub)
  • JinormusJ
    • 6887
    Have you tried holding "set-res" while on AVE MPH and MPG? Usually if the OBC hasn't been reset and has been reading those outputs for a while, you won't have any fluctuations. It's why I usually reset both of them in between fill-ups.
    Now.. If they read -22, you've got a problem. SI-board working correctly? MPG gauge on your tach working as well? If so, you just need to press and hold "SET-RES". Remember, they read AVERAGES, so the longer you haven't reset them, the longer it takes for readings to fluctuate and actually change
    The -22* is simply the outside temp-sensor. This is easily found in the driver side bumper compartment; usually located on the brake cooling duct on late model cars
    • Jed the Fred
      • Feb 2013
      • 51
      Holy sheet thanks!
      • JinormusJ
        • 6887
        Yeah man
        Let me know if that worked for ya
        • Jed the Fred
          • Feb 2013
          • 51
          Yeah man
          Yup everything worked out! Thanks brotha! I just gotta buy a new temp sensor.
          • george graves
            • 19993
            Here ya go: http://www.r3vlimited.com/board/showthread.php?t=153211
            Originally posted by Matt-B
            • Jed the Fred
              • Feb 2013
              • 51
              just purchased one. Thanks!
