I'm replacing a CDA-9885 with a UTE-42BT. Will my new HU slot right in to the sleeve that's already installed in my dash? I'd just try it, but I'm worried about getting things stuck or something and causing more work for myself.
Can I use the sleeve for my old Alpine HU with my new Alpine HU?
I believe those two generations of Alpine radios are the same so it should work. Just compare the new sleeve to the old, if the same, its ok to reuse. If different, I believe Alpine only had two types, then you can swap it out. Only takes 5 minutes or less to swap a cage out.Owner - Bavarian Restoration
BMW and European Electronics Repair and Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
Follow our Instagram!
Originally posted by Cabriolet View Postthe only issue is that the beauty ring must be used from the bracket. otherwise the tabs dont fit. and the ring will pop off
