Confused by electronics
    Hey everyone, I have an 87 325is and when I bought the car, the only thing that worked on the cluster was the tach, the OBC didn't work, and the side mirrors didn't work either. I swapped heads with one I had lying around due to valve guides being worn and after I was finished, all of the previously mentioned things worked with the exception of the speedo/odo.
    I have no idea what caused them to work all of the sudden, but I wasn't complaining. This was about a month ago, and then last week, it went back to the way it was with only the tach working.
    I haven't done anything to the car to cause them to stop working again so I was wondering if anyone has any clue what could have caused this?
    It was nice being able to tell how much gas I had and what the temp was so I'd like all of them back. Is there one plug/fuse/relay all of those things have in common that could have gone bad?
    Thanks in advance,
    Peter
    I'd start by replacing all the fuses associated with the cluster. #10,12, and 21. They are all 7.5A.
    Microcracks in the fuses element can expand with temp and current load causing intermittent operation of circuits, especially in 20+ year old fuses.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
      Well that was easy... that fixed all of the problems lol. Turned out 10 and 12 were blown... I hope they don't blow again because then I'll have to find the reason for that.
      Thanks a lot!
