no power to windows, blower motor fan, or sun roof
  • e-dirtym52
    • Aug 2012
    • 338
    I just swapped out wiring harnesses for my m52 in my e30 after having issues with my first one. Just pulled it out of the garage today to find out I can't roll my windows down or my sun roof. Went to just blow air through my vents and no power there either. But my clock, radio and everything on my dash works fine. Tried to check the powers and grounds but couldn't find anything irregular. Any suggestions??
    If you're not going to do it right, please don't take it out on your car!
  • reelizmpro
    • 9543
    Check your starter wiring. I had the top wire break at the connector
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
      That sounds like the unloader relays aren't engaging. Which would mean that the unloader control wire from the engine harness isn't connected the unloader switch in the starter solenoid or that the unloader switch is bad.
      • e-dirtym52
        • Aug 2012
        • 338
        Which ones the unloader switch?
