windshield wiper stays on
  • digger
    • Nov 2005
    • 6201
    windshield wiper and little fluid pump stays on after i pull the lever to spray water. usually it goes off after a few seconds but mine gets stuck on and pumps forever until i pull the fuse and put the fuse back. it doesnt do it all the time so its intermittent
    what gives? switch or control unit most likely?
  • E30-325iS
    • Sep 2011
    • 191
    Mine did the same, I pulled the control unit, cleaned the pins and re-seated it. That was a couple of years ago and it has been working prfectly since.
    • digger
      • Nov 2005
      • 6201
      ok will give it a go. the control unit is a whole lot cheaper than the switch if i do end up needing to replace it.
