Interior lights not working, cluster lights not working! Stumped!
  • ScottSneed
    • Aug 2013
    • 385
    SOLUTION: BAD (HEAD)LIGHT SWITCH
    Damn, I have been spending a lot of time in the electrical section..fml
    My main two bulbs for the cluster are not working, all other "attention" bulbs are fine. SI battery is fine and lights up too. All the instrument panel lights are not working either.
    I have only one clue, I replaced the bulb for the rear defroster and it worked (bulb lit). If I turn it on, all the instrument panel lights work, except for the cluster. But now the rear defroster light does not work as well!!!
    What I have done
    Replaced all fuses
    Replaced all the bulbs with working or new ones
    Transaction Feedback
    Various E30 Parts for Sale!
    Z3 Steering Racks for Sale!
    Current Fleet:
    -1987 Delphin Grey 325iS
    -1989 Bronzit Beige 325iS
  • Gregs///M
    • Mar 2012
    • 2459
    If you replaced the fuses 10, 12, and 21, and replaced the two large bulbs behind the cluster and still no illumination?
    In this case, I would say you main cluster circuit board could be the culprit. This board can develop solder joint cracks and broken traces over time. This is due to decades of vibration, over tightening the cluster halves, or smacking the dash.
    But make sure fuse 10, 12, and 21 are replaced and still good, even after you replaced them.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • ScottSneed
      • Aug 2013
      • 385
      Changed all the fuses, first thing I did.
      Checked all the solders and refluxed any that looked dead, it still didn't work.
      HOWEVER, I did fix the problem by replacing the light switch, a member on here was kind enough to give me one. the knob was the problem. All my lights work now 👍
      Thanks for the input!
      Current Fleet:
