LED ambient lighting install
  • reelizmpro
    • 9526
    Verts severely lack interior lighting with only a single h5w domelight next to the check panel. In a quest to improve lighting I installed 2 24" LED strips in the footwells on the vert and am very pleased with the results. I used the timed light control circuit BRN/VI as ground and constant 12V +. On the passenger side, I used the flashlight constant 12v+ and BRN/VI ground behind the speaker. So the lights stay lit for a few seconds after the door shuts at least it does in my M technic, other models may vary. It's easier if you want them on/off with the doors without any delay since the door chime wiring is right there. Overall, its a nice touch and shows off the floormats/pedals.
    It's also a good time to check those door switches for functionality.. Mine were broken/corroded and not making good contact. So pull em out and give them a good cleaning with some WD40.
    I bought these really cheap on ebay a while back and never got around to installing them until now. Wasn't sure how much I needed for all my cars so I got 4 120cm packs.
    120cm is about 48inches IIRC. It was too long so i cut it in half and soldered wires on the end to making two separate 24" pieces but even this was a bit too long. 18in would be about perfect.
    The light is much whiter than the picture shows
    This last shot is from outside the car.
    NOTE: the domelight is not on in these pictures but if it were you couldn't with these LED strips. I plan on changing the h5w bulb to LED so it matches.
    These strips are insulated and designed to be used outside of the car. I have seen people use them under the doors/mirrors, etc. so they are durable enough for the interior.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
  • DIIRTY-30
    • 1665
    Very interested to see the results
    BLUE NOSE - M62 SWAP
    THE E30 + 1 BUILD
    • rcsoundn1
      • Nov 2012
      • 3361
      Vert guy weighing in, PICS ASAP
      • reelizmpro
        • 9526
        updated with pics...
        88 M3 - LACHSSILBER
        • DIIRTY-30
          • 1665
          Did this inside my truck & truck bed years ago. Made life at night a lot easier. Never considered doing it to my e30 though.
          Proper execution.
          THE E30 + 1 BUILD
          • Fourbanger
            • Jul 2011
            • 335
            I sure hope they're much whiter than in the pics! LEDs look out of place in E30s to me unless they're on the warm side. Nice work, though, they look like they diffuse well and suit your purpose.
            • cjm
              • Jan 2005
              • 53
              Here is my Vert footwell install using a couple of strips of LEDs from a $30 4 pack sold at IKEA. Also put one inside the glove box.
              Chris Mason - 89 E30 3.0 "Imola3" - 08 X5 4.8i - 92 M-Technic 325i Convertible
              • reelizmpro
                • 9526
                Now that's bright!
                88 M3 - LACHSSILBER
