Hi,
I already checked fuse and the cluster connections, and it seems that there is some connection I'm missing in the speedometer itself as speed isn't being recorded. Anyone knows what to check on what the connections on the PCB of the speedometer are so I could check if they're connected or not? What about connection to tranny?
Pulled down cluster as the odometer wasn't working & thought that the gears were broken. Only found them to be dislodged and put it back together.
This is supposedly a "new" speedo as the PO replaced it, and turned over the old one to me too.
