keep blowing #10 fuse!!
  • ccsdo5
    • Mar 2013
    • 708
    So my 1988 325ix keeps blowing number 10 fuse which is the fuel guage, temp guage, and most importantly the blower motor. I'm not sure if this is a common problem or not but my buddy has a 1986 325es and is having a similar issue. I've gone through making sure all the grounds are good and what not but if anyone has any good idea please let me know! It's cold in NY and I want to keep driving my car for a little before I decide to sell it hahaha!
    -Dee
    5-lugged turbo 318is Barn car
    IG: @deebelmont
  • Gregs///M
    • Mar 2012
    • 2459
    Inspect the local wiring going to the blower motor and the cluster. Also check the wiring behind the radio and OBC.
    Unplug the cluster to see if the fuse still blows, if it does, the problem is not in the cluster. Do the same with the blower until you narrow down the circuit or location causing the short.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • Rc 415
      • Jun 2011
      • 723
      Just happened to me Friday, check you're reverse lights wiring coming from transmission. Mine were melted and grounding out popping #10
      1987 Delphin 325IS
      LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
      Build Thread
      1993 alpine 2 325IC
      •Ground control coilovers•16" BBS RS• momo woodgrain
