Need help installing keyless entry!
  • akwon
    • Dec 2012
    • 144
    Just bought this from eBay, but can't figure out the install. I have researched a lot and the procedure looks very simple (using wires in trunk for lock/unlock...looks super easy)
    I have the LOCK function working by connecting the green wire on the alarm (negative power window output), but cannot figure out UNLOCK. The chart they provided doesn't shed much detail. I have also tested each wire with the trunk's UNLOCK wire to no avail.
    WIRE DIAGRAMS:
    World's leading screen capture + recorder from Snagit + Screencast by Techsmith. Capture, edit and share professional-quality content seamlessly.
  • Cosmic Serpent
    • Mar 2012
    • 154
    For my cheep ebay keyless entry I used the negative trigger diagram if i recall correctly. The issue that you may be running in to is that if the kit is like mine the car needs to be locked via the keyless entry 1st before the unlock feature can be used.
    hope this helps
    • AndrewBird
      The Mad Scientist
      • 11897
      Looking at this diagram:
      You want to use the "Negative Trigger" diagram. The unlock wire is the very bottom one. Connect this to the Green/Purple wire in the car.
      • akwon
        • Dec 2012
        • 144
        I'll give that a shot. Right now, the bottom wire activates unlock.
        Sent from my SGH-M919 using Tapatalk
        • StereoInstaller1
          GAS
          • 22679
          No, that chintzy pile of crap has a garbage manual, the lines are not lined up.
          I bet that bottom wire is ground, then the diagram makes sense.
          See if those hacks used the words "NC" or NO" (Normally Closed or Normally Open) or "30" "87" or "87a" anywhere in that ESL manual in relation to the locks.
          What you should have is 2 wires to ground and 2 wires to the car.
          Closing SOON!
          Thanks for 10 years of fun!
          • AndrewBird
            The Mad Scientist
            • 11897
            Oh wow, that is bad. Didn't even notice. Bottom wire is ground, the wire above it should be unlock.
            • ecsk
              • Nov 2011
              • 106
              These eBay CL kit all come out from same factory, their wiring are all the same
              orange pair - cut out
              white pair - lock/unlock
              yellow pair - connect to +ve for positive trigger, connect to ground for negative trigger
              Just refer to the positive trigger wiring diagrame, instead of connect to +ve, connect them to ground.
              • akwon
                • Dec 2012
                • 144
                Oh boy, if this works, I'll be so happy. Thank you!
                • TSI
                  • Mar 2012
                  • 691
                  I used one of those. Be careful using two transmitters, as if you lock with one and don't unlock it, the other transmitter will be reversed!
                  • akwon
                    • Dec 2012
                    • 144
                    Is there a way you could take a picture of his you wired it?
                    • TSI
                      • Mar 2012
                      • 691
                      Sure, my gf has the car right now and is gone until Tuesday, but I can do it then.
                      • akwon
                        • Dec 2012
                        • 144
                        Hey,
                        Any chance you had a chance to do this? I would really appreciate it!
                        • meddle
                          • Aug 2013
                          • 46
                          It worked for me thank you very very much!:pimp:
                          • akwon
                            • Dec 2012
                            • 144
                            Followed the instructions and it all works except unlock. Maybe my device is defected.
