Anyone have any problems with their fusible link located in the smaller wire leading from the positive battery terminal in your trunk? I suspect I fried my fuse in there but I'm not sure how or where to test the fuse to see if I blew it.. I would have to cut through the wire to get a look at the fuse itself and I'd like to avoid doing that if possible.
If anyone has had to replace this fuse what did you replace it with? I believe from what I read that it's a solid piece of metal connected to the wire? Did you replace it with a new fuse or just wire in the same gauge wore to reconnect the circuit?
Some background info on my problem is a no start issue after attempting to jump start someones car. I have 12v at the power point under the hood which I believe to be the larger gauge cable's power supply from the trunk. My main relay seems to be fine and I tested my coil an I have 12v there as well.. I'm stumped.. I'm getting no spark to my spark plugs or my distributor
