Brake light issue after dash/column swap...
  • strang3majik
    • Aug 2012
    • 310
    I have an 84 318i I just recently swapped an 87 column and switches and a new dash into.
    Ever since this swap, I have no brake lights, and whenever my reverse lights are on my third brake light is on.
    Before the dash and column swap I had no issue.
    Anything I could have plugged in incorrectly or a switch that's not compatible from the 87 column?
  • reelizmpro
    • 9543
    Confused, why did u swap the column? Switches? 84 318 didnt have a 3rd brake light unless it was retrofitted. 84-85 cars are different from 86-on cars. What exactly did you swap over?
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • strang3majik
      • Aug 2012
      • 310
      Well my column was screwed...long story. Fubared ignition and stuck steering wheel lock pin...just got another.
      Plus my switches were all sloppy and the new ones were nice.
      But I swapped an 87 column with all 87 switches (blinker, wiper, cruise, ignition) and a new dash since mine was cracked.
      Before I swapped all this out everything worked fine. After the swap, my third brake light comes on with the reverse lights and I have no brake lights.
      I didn't know if something that needed unplugged from the dash swap could've been plugged in backwards or something causing this.
      Also...a two prong plug with a wire looped (factory) fell out when I did the dash swap. I have no idea where it went. Was a brown wire with a green stripe.
      Also, it appears to be factory third brake light. Its a weird looking package tray with the brake light integrated instead of on top like the later ones. But I've never seen one without.
      • FLG
        • Sep 2011
        • 3165
        I have no idea of your issue but the wire that fell out is for cars with auto trannys , loops the clutch cruise control switch.
        Sent from my SCH-I545 using Tapatalk 2
        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • strang3majik
          • Aug 2012
          • 310
          Ok. Well that's good at least. Must have been taped to the harness then.
          I guess what I'm asking is, do any of the steering column switches or plugs behind the dash have a link to the brake lights? My ignition switch had one less wire, but that wire was cut and taped from my original one so I figured it wasn't important.
          • strang3majik
            • Aug 2012
            • 310
            Found it. Coincidentally the brake switch took a shit at the same time as the dash swap. How convenient. Lol.
