Amp recomedations?
  • Brian 89 325i
    • 1450
    Amp recomedations?
    Im going to get either the MB Quart PSD 213's or the PCE 213's and im unsure on what type of amp i sould get. I was leaning towards Hifonics line but not sure what exact model I should go for. Any Help?
    Brian
  • kencopperwheat
    King of Kegstands
    • 14396
    You just want a 2-channel?
    Originally posted by Gruelius
    • Brian 89 325i
      • 1450
      I was thinking either 2 or 4. Whats better for just running the components?
      Brian
      • bimmerphile
        • 3495
        you can get a hifonics Nemesis 100x2 @ 4ohm - 400 watts RMS total for $180 at thezeb
        The trick with those MBQ's is going to be supplying a steady stream of enough power.
        • kencopperwheat
          King of Kegstands
          • 14396
          I know that some of the MB Quart Musicomp x-overs allow for biamplification. Not sure if the one's you're considering do or not. But if so, get a 4-channel. Then you can run each speaker separately through the x-over. But the 2-channel HiFonics for $180 is a pretty damn good deal.
          • Digitalwave
            is a poseur
            • 6298
            Hifonics rocks. I've got the Zeus 440 watt 4 channel, its brutal. Check eBay for good deals.
            RISING EDGE
            • Mike P.
              • Apr 2004
              • 68
              Re: Amp recomedations?
              Originally posted by Brian 89 325i
              Im going to get either the MB Quart PSD 213's...
              These are EXCELLENT components.
              Just adding a useless 2 cents....
              Mike
              • colt325e
                • 228
                i would reccomend cbrstereo.com or millionbuy.com VERY inexpensive.
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  www.carmedia1.com is less expensive.
