Si batteries
  • tomysss
    • Nov 2014
    • 41
    Si batteries
    Hello. I got a problem with my dashboard:
    My tachometer and fuel consumption meter is not working. Sometimes it does work, but for couple minutes. Sometimes it just get stuck and shows like 3k RPM. Also the fuel gauge works, but sometimes goes straight up as if I had full tank.What causes the problem? and whats the solution?
    EDIT:
    so I took off my IC, and found theese batteries:
    after that, i found theese batteries on ebay and they say they are replacing the ones i'm having now
    "Used in BMW instrument clusters
    replaces Sanyo LS14250SE"
    So am i good to go with theese?
  • Gregs///M
    • Mar 2012
    • 2459
    SI board batteries are failing and the fuel gauge ground is probably loose.
    bavrest.com/si-boards.html
    Tighten the 7mm nut behind the fuel gauge and do the temp gauge while you have the cluster out.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • tomysss
      • Nov 2014
      • 41
      Bump
      • Gregs///M
        • Mar 2012
        • 2459
        You'll have to be really good at soldering to replace those batteries since that SI board has the daughter board which the batteries sit on. I've repaired hundreds of botched jobs from people who try to replace the batteries themselves and end up damaging the circuit traces.
        Also those batteries have no tabs on them, so it wont work unless you spot weld them on, which requires specialized equipment.
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        • tomysss
          • Nov 2014
          • 41
          So what do you suggest me to do?
          • E30-325iS
            • Sep 2011
            • 191
            I bought the correct batteries, with tabs, from batterybob.com. Listen to Gregs///M warning about soldering, if you are not proficient take it to some one that knows how to do it, or just get a remanufactured board from him.
