This week I've been busy working on my amp install.
This is the basic structure:
As you can see it's made in two halves with most of the signal cables running in grooves machined in the boards.
This is the surface the amps will eventually sit on (once trimmed).
Here's a couple of shots with the amps trial fitted.
You can also see the twin cooling fans. I'm not all that happy fitting them in that position, but there's no room at the ends as the amps only just fit between the rear shock towers in the boot. I'll be fitting some vent grills on the front of the enclosure which should also help (see below).
Here's a couple of shots of the underside of the base board. All the big grooves are for the 4 awg power/gnd cables and the smaller ones are for the fan wiring.
I've also been busy trimming everything as well
I still need to paint the vent grills. They are just trial fitted to make sure everything fit's okay.
This is where it sit's in the boot.
I've broken the back of the wiring as well, but don't have any piccies just yet.
Cheers,
Ian.
Cheers,
Ian.
