How about this deck (Clairon DXZ535)
    i just found out formyself, that i can't run a sub with this deck...as it only has 4 rca outputs, what should i do i don't really want to spend more money then i did already. any insights? they fooled me with there sub control :evil:
    also do you think i really need to run subs, i just want good quality i don't need anything to pound, a really good amp and component speaker, do you think that would make up for no subs? i don';t listen to rap, only hard rock, metal, classic rock, some punk.
    what do you think i should do...and advise products to go with it.
    Cam .W '91 325is
    Spaz's 1991 Alpine White???? S52 Build Thread...
      You can most definitely run subs, but you need an amp that will split the rear pre-out signal. My Alpine V12 does it, and I would assume that many others do as well. The only downside is that you cannot fade-out the rear speakers without also fading-out the sub.
      '91 318is
        awesome, i knew there was a way. :)
        Cam .W '91 325is
