Stock radio blowing fuse?
  • shoppingshzhang
    • Sep 2014
    • 69
    Since Sunday, every time I turned on my radio it will blow fuse 12. Does anyone know what might be happening?
    I don't use the radio much so it doesn't affect me much but would like to know what might be going on.
    Thanks
  • Gregs///M
    • Mar 2012
    • 2459
    Pull the radio out and check if its blowing fuses still. A wire might be pinched. If you plug the radio back in (without being installed in dash) and it still blows fuses, you might have a short inside the radio.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • AndrewBird
      The Mad Scientist
      • 11892
      I'd bet the factory amp died and is causing problems. Start by unplugging it and turning the radio on. It's in the trunk near the antenna.
      • shoppingshzhang
        • Sep 2014
        • 69
        Thanks guys. I will take a look and keep you updated
        • Prost
          • Nov 2012
          • 193
          I have another problem: Recently I turn on the radio and the display and antenna (power one) all function, but there is no output (no voice from the speakers at all) Both radio and cassette are the same...any cause? Amp or radio itself?
          92 Alpine White 325iC M-Tech II Appearance Package
          • AndrewBird
            The Mad Scientist
            • 11892
            Could be either. Have you checked all your fuses? What if you turn the stereo all the way? Can you hear anything then?
            • Prost
              • Nov 2012
              • 193
              Nothing even crank all the way...do I have to check all the fuse or only some specific one?
              • shoppingshzhang
                • Sep 2014
                • 69
                Radio is 12 and 21 I believe.
                • Prost
                  • Nov 2012
                  • 193
                  Thanks!
                  • Prost
                    • Nov 2012
                    • 193
                    Check those and fuses are fine (I think I check them all) but still no sound...any other possibility?
                    • shoppingshzhang
                      • Sep 2014
                      • 69
                      Hmm maybe see if you can find something here?
                      • Prost
                        • Nov 2012
                        • 193
                        http://www.r3vlimited.com/board/showthread.php?t=60297
                        Thanks, but I check all fuses in the fuse box and all of them are good...
                        • shoppingshzhang
                          • Sep 2014
                          • 69
                          It blows fuse only if I turn the radio on. If I leave it in off, it doesn't blow any fuses.
