Cluster Swap - White to Blue - 9 LED to 7 LED
  • Jordih
    • Apr 2013
    • 18
    Anyone know if you can swap a late model, 7 LED SI, blue cluster into an early model car that came with a 9 LED SI, white cluster? I want to go from '84 to '91.
    The plugs are the same shape and pin count, but I'm having a hard time comparing each wire from diagrams for each year.
    I have found a couple dead threads about this, no answers.
    :thankyou:
    $500 '84 325e All Year Beater
    Gunmetal Purple
    390,000 KM's
  • AndrewBird
    The Mad Scientist
    • 11892
    No, they are not compatible. See here, post #6:
    • Jordih
      • Apr 2013
      • 18
      It seems they were talking about interchanging components, though I don't see anything mentioning swapping the entire cluster from 9 LED to 7.
      Gunmetal Purple
      390,000 KM's
      • AndrewBird
        The Mad Scientist
        • 11892
        Yes, I suppose you are correct about the thread, but I'm fairly certain it's not as simple as just swapping clusters. I know the gas gauge changed from early to late and since early and late clusters can't swap parts, you can't just swap the gas gauge.
        Why do you want to change?
        • Jordih
          • Apr 2013
          • 18
          I have the S.I. Shift Light kit for 7 LED clusters, but no longer have the car I was going to use them for, but I have a 9 LED car and a spare 7 LED cluster.
          Gunmetal Purple
          390,000 KM's
          • Gregs///M
            • Mar 2012
            • 2459
            Yes, you can swap a late model cluster for an early model and vice versa. I usually replace my clients early model clusters with late model clusters configured for an early model car. I do this because quality non damaged parts are more readily available and the late model cluster is more robust electrically.
            Also, the speedometer, fuel and temp gauges are interchangeable between early or late model clusters. It seems only the tach/MPG is the only gauge not interchangeable and must stick with its original generation.
            But to answer your question, you will need to swap in your 7 LED cluster to install your shift light kit. I also recommend you replace the SI board batteries in your 7 LED cluster while your in there. Swap your early model fuel gauge and speedometer and you will be good.
            Owner - Bavarian Restoration
            BMW and European Electronics Repair and Restoration
            www.BavRest.com
            My Feedback Thread
            Our Facebook!
            Follow our Instagram!
            • Jordih
              • Apr 2013
              • 18
              So, swap in my 9 LED cluster fuel gauge & speedo into my 7 LED, install new SI batteries, install shift light kit, then plug and play?
              Gunmetal Purple
              390,000 KM's
              • Gregs///M
                • Mar 2012
                • 2459
                Exactly!
                www.BavRest.com
                My Feedback Thread
                Our Facebook!
                • Jordih
                  • Apr 2013
                  • 18
                  Wow, sounds easy. I'll try it out.
                  Thank you for the great info!
                  Gunmetal Purple
                  390,000 KM's
                  • Jordih
                    • Apr 2013
                    • 18
                    Wow, sounds easy.
                    I knew I would regret saying that... :oops:
                    It was going great, up until during the set up of the shift lights.
                    My tool to turn those little dials slipped and connected the two exposed pins.
                    Lights off, little puff of smoke... I fried the SI board. :curse:
                    Notice the brown mess underneath the last pin...
                    Gunmetal Purple
                    390,000 KM's
