So my power windows on the passenger side is being a bitch and a half. Ive noticed that you needed to push down with alot of force on the switch only to raise the window, and sometimes it would just stop regardless and youd have to press the switch down again a few times to get it to go again. Now it just cuts out completely and it takes like 30 tries to get it up. Is this a window motor problem or is the switch just a piece of shit?
passenger window being a bitch
Tags: None
It's just the switch and its very common. Replace the switch and all should be fine again.Eric Giles
'20 M2 CS
'04 M3
'11 X5 35D
'87 325is
'91 325i Sport
There are few things more expensive than a cheap BMW... -
Cool. Its 95 degress right now and Ive got a 400 mile drive ahead of me so hopefully itll decide to go up if it starts to rain or something. Anyone know if the e36 switches are worth the cash?Back to my roots
If you have an electric sunroof-and you won't be using it-for now you can just swap its switch with the window switch since they are the same until you can get a new one.
No doubt the E36 switches are of a better design, but its not something I would mess with personally.Eric Giles
'20 M2 CS
'04 M3
'11 X5 35D
'87 325is
'91 325i Sport
There are few things more expensive than a cheap BMW...Comment
I got a new switch on the way. Ill clean up my one now and hopefully keep it as a spare.Back to my roots
