White wire behind radio ?
  • jeffnhiscars
    • Jun 2011
    • 6011
    I pulled the factory cassette player today only to realize it didn't work cause it was discover it was completely disconnected..not that it matters since I have a new Kenwood to pope in.
    Question is what is the twin lug white wire for?
    Alice the Time Capsule
  • chadthestampede
    • Jul 2008
    • 3601
    One is for the power antenna, the other for the amp. Refer to this post:
    First, let me say this is NOT applicable to all E30s. Generally, Late Model (88+) will have this wiring on premium sound cars. IF you have a fader in the dash, this MAY work: you need to unwrap about 8" of fader harness to see if you have 4 pairs of speaker wires, as some cars have only 6 wires, not 4 pairs (8 total) so if this chart does not apply PERFECTLY to your car, don't use it.
    Quick disclaimer: this is not idiot proof. You mess it up, don't whine at me, I do not care.
    If this saves you countless hours of hassle or you are just feeling generous, feel free to paypal me a tip. Add "@gmail.com" to Stereoinstaller1 and I promise to only use the money for projects on my car.
    OK, here is the info.
    Obviously, what you do here is simple: connect the "deck" wire to the "dash" wire, then back at the trunk, connect that "dash" wire to the "speaker" wire.
    This is not rocket surgery, boys. Get it done.
    Aftermarket-----------Dash Wires-----------Speaker Wires
    RF+ Grey--------------Blue/Red-------------Grey/White
    RF- Grey/Black--------Brown/Orange--------Grey/Brown
    LF+ White------------Yellow/Red------------Grey/Red
    LF- White/Black-------Brown/Orange--------Grey/Violet
    RR+ Violet------------Blue/Black------------Black/White
    RR- Violet/Black-------Brown/Orange--------Black/Brown
    LR+ Green------------Yellow/Black----------Black/Red
    LR- Green/Black-------Brown/Orange--------Black/Violet
    (+12V Unswitched) Yellow----Red/Green (Changes to Yellow at C302)
    (+12V ACC) Red-------------Violet/White (Changes to Voilet/Grey at C302)
    (Ground) Black---------------Brown (may also be Brown/Black)
    (ILL) Orange-----------------Grey/Red (Changes to White at C302)
    (P ANT) Blue-----------------White (this is one of 2 white wires)
    (AMP REM) Blue/White--------White (this is the one in the same harness as the speakers)
    Luke
    and this
    Originally posted by accident
    for what it's worth, every E30 i've wired the two white wires were connected to each other and went out to a single white wire for the stock deck. apply 12v to each until your antenna moves would be my guess :)
    Originally posted by LJ851
    Feedback
    • jeffnhiscars
      • Jun 2011
      • 6011
      I actually have Luke's post printed (in color) but this is a non premium car with no amp so I'm cross checking since I did not see anywhere the whites would connect. This is not 2 whites but rather one w a pig.
      Are you thinking they are prewires for,premium sound and are thus spares ?
      • lambo
        Captain Scene Points
        • 10953
        Antenna
        • jeffnhiscars
          • Jun 2011
          • 6011
          Originally posted by lambo
          Antenna
          I had missed the small terminal on the radio that confirms this. The large terminal is for the non existent amp
          Thanks
          • Dzdimi14
            • Jan 2015
            • 158
            Haha I just ran I to this. I just left it capped off. My antenna doesn't go up and down anyways so I guess that I did the right thing
            Sent from my A0001 using Tapatalk
