Nooo! I short circuit-ed my 91' 318is
  • salvuhdor
    • Jan 2013
    • 445
    Car: BMW 1991 318is m42
    I have the 6 button On board computer (OBC)
    While doing a head gasket job I decided to install the euro clock while I wait for parts. Stupid me stripped the wires naked and left them like that when the parts came in.
    So when I was done with the Head gasket I proceeded to connect the battery and turn on the car (with the wires exposed and touching)...
    My car didnt crank and heart sunk. After seeing the wires I closed my eyes in disgust. I taped up the wires and car started but then both my RPM and MPH gauges did not work!
    Later my Speedometer started working but RPM's still does not read... should I start taking out the cluster right now? I looked at all my fuses and none were broken but I did not mess with any relays.
    ---------Looking for advice pleease!
    KW: Tach tachometer speedometer gauge cluster clusterboard SI fuse fuses relay
  • bmwman91
    • Oct 2004
    • 3134
    Fuses 12, 21 and 23 are the ones with power connections to the OBC. Fuses 12 and 21 are also shared with the cluster.
    A quick visual check is not always going to tell you if one of those little fuses is blown. Pull those out one at a time and check them for continuity with a multimeter. If you don't have one, then get a flashlight and check closely.
    Honestly, you are probably fine. One of those fuses blew, and they are in there specifically to protect much more important/expensive subsystems in the event of a short circuit.
    Transaction Feedback: LINK
    • salvuhdor
      • Jan 2013
      • 445
      Yes, the euro clock does not respond so i am hoping you are right=)
      • audiquattrot
        • May 2008
        • 3836
        yeah u just blew a fuse, assuming you had the right 7.5A one in there....if not u fried something (cluster)
        had a similar issue, and mine was fuse #21. Half the cluster lights were out and clock.
        www.instagram.com/snwmble
        #snwmble
        Current:
        '05 BMW M3 - Silver Grey/Imola Red
        '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
        '15 Mini Countryman - Blazing Red/Carbon Black
        Past:
        '01 Audi Allroad - Light Silver/Platinum Saber Black
        '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
        '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
        '90 BMW 325i - Schwarz/Tan sport *Sold*
        '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
        • audiquattrot
          • May 2008
          • 3836
          this is what happened to my cluster, when I shorted the euro clock. Turns out I had the wrong amp fuse (#21), hence why this happened.
          #snwmble
          Current:
          Past:
          • salvuhdor
            • Jan 2013
            • 445
            Thank you guys- my dumb butt didn't clearly look at it. Appreciate it!
