This sounds pretty stupid but(same as below) my window is giving me problems also--exactly how and with what do I clean the switch with?
Newbie
try swapping the switch with the other known working switch (assuming you have one). If the problem follows the switch replace it.
M -
Originally posted by ponner1usThis sounds pretty stupid but(same as below) my window is giving me problems also--exactly how and with what do I clean the switch with?
If you must clean the switch and not replace it then use a can of Contact Cleaner from the local Home Depot or Lowes.
