Service light
    Service light
    Hey guys, oil service and inspection light along with the yellow light have been on ever since I purchased the car several months ago. Used the wire method to reset. Three of the five green lights lit up and then went off. The inspection light will not go off though. Is this a sign of bad batteries on the board?
    Thanks
    to make the inspection go off you have to leave the wire connected for a few seconds longer than for the oil lights. It's weird that only three green lights came back on though. Maybe that's related to the inspection light
      I left the wire connected for about a minute and the inspection light never went off. The oil service light went off after about two or three seconds. The inspection light never did. I'm just thinking bad batteries on the si board. On a side note. Is there any way to tell which kind of batteries your board has without taking the cluster out of the car first?
        I have the cheap ebay tool that makes this easier. Worked on my US spec cluster. Now I have a euro cluster and it wont turn the service light off
          If your service lights will not reset, the SI board batteries are dead.
          You cannot tell which batteries are equipped on the board without disassemblying the cluster unfortunately. If you want to learn more about the Si board, read the technical articles page at our website.
          Owner - Bavarian Restoration
          BMW and European Electronics Repair and Restoration
          www.BavRest.com
          My Feedback Thread
          Our Facebook!
          Follow our Instagram!
            I believe 86+ has the newer lithium batteries, whereas 84-85 has the nicds which fail and leak. If you have three red service lights you most likely have the nicd batts. But it's best to take it apart and see. Popping the cluster out isn't hard, but make sure you memorize how it came out because putting it back in can be tricky and misleading
              NiCad batteries show up in all years.
              My 1990 is had a NiCad board
              I wash BMWs all day at a dealership. Do you have any idea how much i8's suck to do anything but look at?
                Do you have a momo meter cluster? My '87 with a VDO has lithium batteries
                  Lithium batteries weren't on the market then BTW...
                  Closing SOON!
                  Thanks for 10 years of fun!
                    Then my cluster must have been refurbished at one point. Which explains why my odo works...
                      Score!
                      Closing SOON!
