This is for my e36 convertible.
I just finished an entire audio install/upgrade. Went from all stock to all new aftermarket.
Hopefully what follows are some useful specs:
HU: KENWOOD KDC-BT958HD
Front Speakers (tweeters and woofers): Pioneer TS-D1320C
--5.25" woofer, 1.125" tweeter, 180w max, 35w nominal
Front Speakers (mids): the mids from the BSW kit - unknown specs
Rear speakers: 5.25" Kenwood Kfc-P509Ps
Amp (front speakers): Blaupunkt EMA 255
--55 watts RMS x 2 at 4 ohms (80 watts RMS x 2 at 2 ohms)
--selectable high-pass filter (80 Hz, 12 dB/octave)
Amp (subwoofer): Rockford Fosgate R500X1D
--300 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
--variable low-pass filter (50-250 Hz, 12 dB/octave)
Subwoofer: Infinity Reference 860W
--8", 250w rms, 1000w peak, single 4ohm impedence
The front woofers and tweeters are powered by the blaupunkt amp which is taking low voltage input via rca from the HU.
The front mids are powered directly from the HU (this was the only way I could keep them) and wired up with audyne 47uf capacitors for filters.
The rears are also powered directly from the HU.
The subwoofer is powered by the fosgate amp which is taking low voltage input via rca from the HU.
I have read and successfully used Luke's guide for amplifier tuning on my e30 in which all speakers are amplifier powered. What I am not so sure about is the best way to go about tuning the system in the e36 given the layout is using both amplifiers and the HU to power speakers.
At the moment, I have tuned it as follows:
Front woofer/tweeter: find reference volume of HU (turn all gains down, HU volume up until distortion), at max reference volume turn up gains until distortion and back down a little (I also selected the HPF on the amp)
Front mids: started with the gain setting in the HU all the way down, turned it up until the sound was balanced with the woofer/tweeter and no distortion (no HPF selected - relying on the cap)
Rear woofer/tweeter: with HU at reference volume, turned up the gain in the HU until it sounded balanced with the front and was distortion free, I also turned on the HPF in the amp (don't remember what setting)
Subwoofer: tuned according to Luke's guide
So basically I am looking for feedback and advice on how to tune this system in the best way. Have I done it correctly already? There are way way more adjustments than I know how to use in the HU and I am afraid to mess with most of them because I don't understand them.
Here are a few pictures of the install
I know the box is smaller than ideal - it's what I could fit. Considering using some polyfill to help it sound a little better? Thoughts?
And finished
Also mounted the sub control knob here
Thanks guys!! Any help is appreciated!!!
And finished
