I need help with a radio install
  • ricksifuentes
    • Aug 2012
    • 16
    Hi there fellow members I need help installing an aftermarket radio in my 1991 318is it has a Pioneer cassette with 6cd changer and I can't find a wiring harness for the aftermarket install...thanks in advance
    P.S. I cant seem to download the picture to show what I'm working with
    Last edited by ricksifuentes; 04-26-2016, 06:33 PM. Reason: picture dowload failed
  • ricksifuentes
    • Aug 2012
    • 16
    bump
    • e30strokr
      • 211
      I tried to find one too but mine was already hacked.. search here to find out how to wire one up .... stereoinstaller says to remove the fader knob/wheel and you will see 4 wires for front and back, then you will need to figure out ground and power.... .. I need to redo mine since PO just hook up the stereo with the front wires only....
      • Das Delfin
        • Sep 2014
        • 2293
        you are going to have to find a wiring diagram which shows you the bmw wire color codes and then match that with what is coming form the stereo.
        I have a haynes manual which has a section full of wiring diagrams and I used that to install my stereo a couple years ago.
        There are two different setups: premium sound and standard. Figure out which one you have and go from there. It's really not hard once you know which wire is which
        • ricksifuentes
          • Aug 2012
          • 16
          Thanks for all the advice
          I'll definitely need to know what I have because the radio it has on looks very original to me but it's not bmw tho...it's a Pioneer cassette player and it's hooked up to a 6cd changer also
