CD43 speed sensitive volume control
  • PKile
    • Apr 2016
    • 184
    Hey folks...I've retrofitted a CD43 deck into my 92 vert and was hoping to enable the speed sensitive volume control. I ran a wire from pin #10 on the radio plug to one of the two out of 3 open terminals on the green cluster plug, figuring that would give me a speed signal. The speed volume function doesn't come up when I toggle between fade, balance, etc. Any ideas? I hope the IBus wire isn't involved...
    Thanks in advance,
    Paul
  • george graves
    • 20003
    I'd take a look at the wiring diagram of a CD43 on a typical/factory BMW install and see what it's connected to.
    Originally posted by Matt-B
    • PKile
      • Apr 2016
      • 184
      I may have just answered my question...duh! I searched for CD43 speed signal and discovered I was accessing the wrong selector to get to the speed setting. I was pushing the musical note where I should have been pushing and holding the m button. Now the problem is the car is laid up in the middle of an engine rebuild and suspension refresh...it will be at least another 2 months before I can power up the radio!
      • august125
        • Aug 2011
        • 57
        Cool. Glad to know how to activate it. I have a lead I cut out of a parts car and a C33 that should have speed sensitive volume, but I haven't hooked it up yet. I'll post back here once I do.
        • PKile
          • Apr 2016
          • 184
          I did the same thing...cut a speedo trigger lead out of a junkyard car and ran it to one of the two open pins on the green cluster connector. Spliced the other end to pin #10 on the 17-pin radio connector.
