Residual current absorption on cluster
  • scipio84
    • Aug 2016
    • 19
    Hello, during my vacation, I left my E30 parked for about 3 days and forgot to disconnect the battery. Well, after only three days the battery was discharged.
    Perhaps, it was not that good, however there was clearly something.
    So I began some measurements and found out that something in the cluster absorbs current.
    With the negative cable disconnected from the battery, I measured, between negative post and ground, about 70mA. When I disconnect the blue connector of the cluster (Motometer), the residual current is about 4mA.
    What does that connector connect? What can I check in the cluster?
    I need to reduce the circle of the possibilities as much as I can, I'm worried about problems to the cluster...
  • Steve Corbett
    • Jul 2012
    • 449
    Try here first...
    Steve Corbett
    1983 528E Scrapped
    1983 528E Sold
    1984 745I
    1984 325E - Sold
    1989 325I Bronzit-Sold
    1989 325I Zinno
    1988 635CSI
