Replaced Motometer cluster gears, but still no odometer! What gives?
  • phreshkid
    • 4655
    Hi guys,
    I pulled one motometer cluster out and verified it had bad odometer gears. I had a spare motometer cluster with good gears and threw that in, but still no odometer registering. I thought hmm, maybe there is another odometer issue with this one too, so I bought the Garagistic Odo gears and swapped them in to my original cluster. Everything appeared to be working mechanically, so I swapped in the old cluster.
    Everything works, but the odometer and trip meter! What can cause this? Is there a way I can test the electrical system?
    This is breaking my balls and testing my patience. I've burned cars to the ground for smaller issues than this.
    Help!
  • e30rapidic
    • 2167
    do you have an extra SI board you can swap in to test?
    '87 325ic, powered by S50.
    • Gregs///M
      • Mar 2012
      • 2459
      SI board has nothing to do with the odometer.
      If your speedometer needle works, and your odometer does not, most likely cause of your failing odometer is poor installation of replacement gears or failed odometer motor or drive electronics. VDO brand is particularly common to see failed electronics.
      If both your speedometer and odometer failed, the problem is either fusing or the connection at the rear differential speed sending unit.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        I am having same issue with mine. After 3 cluster I'm just getting one rebuilt
        1991 318i 4dr slick top
        Mtech 2 turbo restoration
