Wiring Schematics?
  • kencopperwheat
    King of Kegstands
    • 14396
    Wiring Schematics?
    A friend of mine is an electrical engineer and we're thinking about making some one-touch window/sunroof modules as well as some automatic headlight modules. He just needs the factory wiring diagrams/schematics for the two systems. Where can these be obtained?
    Originally posted by Gruelius
  • turnofftheradio
    • Apr 2005
    • 448
    it is at e30tech. almost all years.
    • StereoInstaller1
      GAS
      • 22679
      Dude, waitadamnminuite here...your buddy is a full blown EE and needs a schematic for a basic voltage reversal switch? Not even a relay involved.
      You must not know how simple these are. Both wires rest on ground, switch to 12V for activation. The sunroof is the same way, but the motor pushes it up instead of just closed...not electrical, but mechanically.
      is my quickie write up in the cheap module I carry.
      Any Q's, give me a shout.
      Luke
      Closing SOON!
      Thanks for 10 years of fun!
      • kencopperwheat
        King of Kegstands
        • 14396
        He's graduating from PSU this week with an EE degree. He didn't say that he needed it, but it may make it easier. He said he needed them moreso for the automatic headlight on/off.
        He's going to make a module so that when you tap the up/down button twice it will go all the way up/down. We're going to hopefully make it as "plug and play" as possible.
        • kencopperwheat
          King of Kegstands
          • 14396
          Originally posted by turnofftheradio
          http://www.soulblighters.com/e30tech/
          link no workie
          • StereoInstaller1
            GAS
            • 22679
            Yeah, I could see that. Auto headlights are cool. Photosensitive? I have installed relays on headlights to make them "ignition only", so basically they shut off with the key.
            2X trigger would be cool.
            Doesn't the E36 "one touch" window switch have some extra wire to toggle that circuit? If so, they would work on the module that I carry.
            I really like the "100 degree vent" feature that the Scytek ones have. Some have said otherwise, but I love it.
            1990 Mazda 929's have a solar-powered fan and a sunroof vent feature for temps over 95 degrees...I would love that!
            Luke
            Closing SOON!
            • kencopperwheat
              King of Kegstands
              • 14396
              The 100-degree vent would be badass. Maybe a thermal sensor built in to the module that lowers the windows 1" or something? I'll bring that up with him.
              Yeah, the autoheadlights would use a photosensor. The most difficult part would be where to actually mount the sensor. Do you know where they are in newer bimmers? Or any other cars for that matter. It seems like you'd want it on the side so that headlights aren't triggering it.
              • StereoInstaller1
                GAS
                • 22679
                Most have a sensor on top of the dash, out of view of the domelamp, plus usea timer so it has to be pretty light for quite a while to shut them up. Errrr...off.
                Luke
                Closing SOON!
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  Luke
                  Well that makes sense. It would probably be easiest to mount the photosensor on the left side of the cluster on top of the dash (close to the switch too). Proabably have it programmed so that with 5 sec of continuous darkness they come on and 15-20 sec of continuous light they turn off.
                  With the stock switch there would only be an off/auto option though. Maybe we can get one of these whipped up in a week or so. Should be fairly inexpensive.
                  • turnofftheradio
                    • Apr 2005
                    • 448
                    link no workie
                    yeah, just checked :( occaisionally it goes down, hopefully it will come back up soon. if not pm cronikus at e30tech, he hosts this
