What Can I Tap into Near the Glovebox to Get Accessory Power for AirPlay
  • word is bond
    • Apr 2012
    • 503
    I've got my stock head-unit in my 318is outfitted with an aux jack, but I'd love to connect that to an Airport Express in the glovebox so that I have a hidden wireless way to play music through the stock stereo. I have very little electrical know-how, but I'm guessing that whatever I tap into would be 12V, which would then need to be stepped down to the 3.3V that the Airport Express needs with a regulator or converter? Does that all sound right?
    So if this plan sounds kosher, what can I tap into near the glovebox? And can anyone recommend a regulator?
    diamantschwarz 1991 318is
  • parkerbink
    • Jun 2004
    • 10138
    Flashlight charger receptacle.
    • AndrewBird
      The Mad Scientist
      • 11898
      Airport express is a wifi router, correct? How exactly are you going to use that to connect to the radio?
      • word is bond
        • Apr 2012
        • 503
        Any other options besides the flashlight receptacle? I actually have a flashlight plugged in there...
        You can use them as a router or a wifi extension, or you can just use them for Apple's proprietary version of bluetooth called "Airplay," which I believe has a bit better sound quality than bluetooth. They have a 3.5mm jack on the back, which you can connect to a set of speakers, so that would just run into the aux input I already have connected to the radio.
        • parkerbink
          • Jun 2004
          • 10138
          Tap in on the other side of the flashlight.
          • earthwormjim
            • Jul 2014
            • 434
            It has an audio output, and OP said he has an AUX input to his radio.
            Why does that matter, you would be tapping into the back of the receptacle.
            • word is bond
              • Apr 2012
              • 503
              Oh right — I am an idiot. Thanks.
              • parkerbink
                • Jun 2004
                • 10138
                Post2
                Post5
                You are welcome.....
