Factory premium amp PN 65 121 375 983 info please
  • parkerbink
    • Jun 2004
    • 10138
    Finished my radio replacement yesterday, didn't know I had an amp, it's this one on the driver side trunk wall:
    65 121 375 983
    [IMG]s-l1600 by phled1, on Flickr[/IMG]
    Anyone know the specs? and also since the output is speaker level, is it getting the HU's power plus the amps?
  • bobdavisnpf
    • Apr 2017
    • 56
    This amp replaces the HU speaker-line power with its own. It takes speaker-level input and puts out 25 wpc x4. At 0.1% THD its output is 10-12 wpc x4. Not very much oomph, and like any small amp is prone to clipping at speaker-damaging levels when driven too hard. The stock 8-ohm speaker coils & crossovers may be tanky enough to withstand the clipping but if you upgrade to 4-ohm or even 3-ohm speakers I'd say all bets are off.
    Looks just like the amp I pulled from my e30 when I replaced the original cassette deck with a CD43. The CD43 is "high power" using the same amp chip onboard as is used in this amp, so I basically did not upgrade the main amp in my build. I added a couple Kenwood powered bass boxes, upped their gain a little, and lowered bass at the HU. That saves the HU amp more for mids & highs which take far less power and 10 wpc is plenty.
    • parkerbink
      • Jun 2004
      • 10138
      Thanks
      • george graves
        • 20003
        Really? Wow - same IC?
        Originally posted by Matt-B
        • bobdavisnpf
          • Apr 2017
          • 56
          No! I was wrong.
          The amp in question - Blaupunkt BMW pn 7 607 395 140
          I'm gonna go with 8 wpc at 1% THD, with clipping at 9 wpc and 10% THD.
          This amp has 8 ST2003 amp chips. The 1-channel ST2003 can't do 0.1% THD, but at 0.11% it's good for 4wpc to 4 ohms. At 1% THD it's 5 wpc to 4 ohms. I guess each channel has 2 amp chips, with a crossover separating lower and upper frequency ranges, then post-processing to gang the 2 amplified signals. This would net a theoretical max of 10wpc into 4 ohms at 1% THD, but if the bass signal is only gonna get 5 wpc then your effective max is probably more like 8 wpc.
          Link to TDA2003 spec pdf:
          It does have decent thermal management, imo. Those 8 little phillips-head screws between the fins are the heat-sink mounting screws for the amp chips.
          The CD43 uses 2x TDA7376B amp chips. The 2-channel TDA7376B can do 0.03% THD at 10 wpc into 4 ohms; it's still at just 0.08% THD at 15 wpc into 4 ohms. (Or, it hits 1% THD at 11 wpc, depending on if you read the summary chart or the THD chart)
          The CD43 packs its 2 amp chips in on one side of its enclosure, with a narrow air channel for heat dissipation. Still, I've got the impression now that the CD43 alone is an upgrade to the E30 outboard amp -- and that almost any modern head unit on its own will also be a significant improvement over the E30 outboard amp.
          Link to TDA7376B spec pdf:
