Hidden Antenna Reception
  • AlecB
    • Jul 2017
    • 19
    Hello! I recently bought my first E30 ('91 vert) and noticed the radio is unusable -- it works well enough when the car is sitting still, but as soon as I start to move it begins cutting in and out. I immediately checked the antenna and noticed it doesn't have one. There's just a black plastic cap covering the hole where the grommet should be.
    I'd like to keep that sleek look, but was wondering how a hidden antenna's reception would compare with the stock antenna's. I'm also considering buying a power antenna instead, but as I don't know if the car originally had a power or manual one I don't know if the it has the wiring to run a power one. Thoughts?
    Thanks,
    Alec
  • ELVA164
    • 4861
    I'm pretty sure the previous owner just deleted the antenna. All cars have the wiring in place for the power antenna, so that's not a big deal.
    • Das Delfin
      • Sep 2014
      • 2293
      An antenna's vertical length determines the quality of its reception. The longer it is the better it works. I haven't seen an e30 with a manual antenna.. and not very many working power ones either. I put a generic $10 advance auto 3 foot mast antenna in mine.
      Your car will have wiring for a power antenna. Look in the driver side of the trunk compartment up near the hinge for red, white, and black wires, as well as the antenna signal wire, which I believe is gray
      • glnr13
        • 1334
        http://www.realoem.com/bmw/enUS/show...diagId=65_0373
        my weirdo car came with the manual antenna pictured in the link i posted to the left. No part number listed on that page either.
        • g.ruff561
          • 1267
          There was a write up some time ago about converting the rear window defogger into a pretty stealth AM / FM antenna. Never tried it but it sounded interesting. Then you weld antenna opening closed, smooth over and paint. Could not find that write up.
          • glnr13
            • 1334
            would the defogger still be functional or does it permanently change it's function to antenna?
            • g.ruff561
              • 1267
              From what I can remember, it permanently disables rear defogger. I'm in FLA. I do not need rear defogger. If it works it would be great to have the option.
              • AlecB
                • Jul 2017
                • 19
                Thanks. Looks like I'll get an aftermarket powered one then -- I'd rather keep it authentic, but a manual antenna seems like a real pain, and the powered ones seem expensive.
                • g.ruff561
                  • 1267
                  Try Z3 antenna.
                  • parkerbink
                    • Jun 2004
                    • 10138
                    S2000 antenna is a small rubber deal that gets great reception. fwiw
                    • 15Michaeljoseph
                      • Aug 2013
                      • 1693
                      Come see my working power antenna ;)
                      Sent from my XT1064 using Tapatalk
                      (OO=[][]=OO) For Life
                      • nrubenstein
                        • 3148
                        Using the defogger isn’t the worst option, given E30 rear window’s tendencies to explode while defrosting.
                        2002 BMW M3 Alpinweiß/Black
                        1999 323i GTS2 Alpinweiß
                        1995 M3 Dakargelb/Black
                        - S50B32/S6S420G/3.91
                        1990 325is Brilliantrot/Tan
                        1989 M3 Alpinweiß/Black
                        • g.ruff561
                          • 1267
                          I would not mind trying it. Hell I tried everything else from oem units to Z3 mods. Anybody got have knowledge they care to share?
