My car is missing the battery vent and mounting bracket
  • ZekeTheSneak
    • 1562
    I have a 91 318is. I finally got around to bolting my battery down since the car has been sitting. I purchased a new battery last year and the clamp that holds it down is too far away. Realoem shows a spacer that I may need? I probably bought the wrong battery from the dumbasses at autozone.
    Also there is no vent tube or overflow thing below the battery. Do I need to order the overflow bottle or should i just run the vent tube down to the grommet in the sheet metal?
  • jrobie79
    • Mar 2006
    • 2525
    I just ran my vent tube into the grommet in the metal
    1991 318i ---- 308K - retired
    • monty23psk
      • Mar 2008
      • 1289
      My project thread in the early pages has this topic figured out. Issue is that the stock collector at the time was NLA. I had to buy it used on eBay. You should use a vent and collector to prevent battery acid vapors. This can lead to rust underneath the battery.
      Alex 88 m5 | 91 318is | 19 Subaru Ascent
      BMW Tool Rentals & Fender Roller
