Alternator insufficiently charging battery
If your battery is 5 year old or older, it may need to be replaced. Bad voltage regulator in the alternator is another common problem. To achieve healthy electrical charging system do the following:
-Make sure battery is 5 years or younger
-Make sure battery to chassis ground cable is healthy and good connection
-Make sure oil pan to frame rail engine ground cable healthy and good connection.
-Make sure voltage regulator in alternator is replaced
-Make sure alternator mounting is clean and solid or auxiliary alternator ground cable will be needed/recommended.Owner - Bavarian Restoration
BMW and European Electronics Repair and Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
Follow our Instagram!
