Alpine CM5908: RR no sound
  • boomer
    • 3019
    I have an Alpine CM5908 and all the channels work with the exception of the right rear.
    Anyone have an insight into this problem?
    http://www.arghon.com/
  • e30davie
    • Apr 2016
    • 1788
    Start tracing the wires from your head unit to your speaker, no other way really.
    Unless the rear right isn't plugged in....
    • boomer
      • 3019
      Thanks for responding. I'm bench testing the unit at home and I feel the problem is within the radio.
      I have spare radios and could probably just replace the defective part.
      • e30davie
        • Apr 2016
        • 1788
        ahhhh well thats a different story.
        Id start by pulling the casing off and looking for components that look like the smoke has been let out of them.
        I have successfully repaird electronics in the past by desoldering and re-soldering components on the board. Just trace the tracks around the circuit board and see what you can find. It might even be a dry solder joint somewhere on the board, that is worth checking also.
        • boomer
          • 3019
          I was thinking something similar, thanks bud.
