Strange Problem - Power 'cutting out' *WTF*
  • jrobie79
    • Mar 2006
    • 2526
    1991 318is
    Audio Setup:
    Class D 1000W Memphis amp - powering Fi Q 12" Sub
    Class A/B 250W Orion Amp - powering two PPI-365cs components
    2 gauge amp power wire/ground wire
    Pioneer DEH-80prs deck, internal amp turned off
    When I'm driving I notice (fairly frequently, couple times on my hour commute to work) the head unit will "shut off" and I noticed the Anti-lock light light up on my instrument cluster for a second.
    When this happens it cuts out the bluetooth connection from my deck/phone and I have to manually reconnect. I also noticed the headlights, and even the interior lights, hazard button, defrost button, cluster lights, dim with the music, even when there isn't much bass.
    I upgraded all the engine grounds, chassis grounds, to 2GA wire and copper lugs with good clean connections.
    Is this a battery issue (exide from Advance Auto) or alternator? The alternator belt is sufficiently tight, so I was thinking possibly the alternator itself as it happens when driving. Not sure if I have a 70A, or 80A alternator but I saw a 90A alternator available. I'm going to upgrade the alternator power wire when I have a minute, but if I need to replace I'll definitely add a thicker wire when its all apart.
    1991 318i ---- 308K - retired
  • Gregs///M
    • Mar 2012
    • 2459
    Replace those 30 year old fuses with new ones and the problem will probably go away.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
