1986 325e speakers: recommendations?
  • e30owner
    • Feb 2016
    • 14
    Hey guys,
    I'm the original owner of a 1986 325e with Premium Sound, fader in the dash, amp in the trunk. The head unit is an Alpine CDE-163BT (soon to be replaced by a CDE-HD149BT because the blue Power Antenna lead on the former keeps the antenna raised all the time, even when AM/FM is not selected).
    I've been thinking about upgrading the amp and the speakers. But that would be a major project, especially since I don't know very much about audio. Would it make sense to just replace the speakers?
    In the front, there are two component speakers with 1" tweeters in the door and 5.25" 40-watt 4-ohm speakers in the kick panels. On the rear deck, there are two coaxial speakers with 40-watt 4-ohm 5.25" speakers and 1" tweeters at an angle beside them. The speakers are stamped "ITT W Germany." They look like they have paper cones. Would it be worthwhile to replace these speakers? If so, what would I replace them with? Advice would be appreciated.
  • reelizmpro
    • 9530
    I would replace them. Decent replacements can be had pretty cheap and they'll be able to handle the power of the new headunit. There are many, many options here. Just depends on your budget.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • isaac.delgado
      • Aug 2018
      • 8
      Originally posted by e30owner
      Hey guys,
      After tons of research and after been told that the factory premium speakers are the ultimate option for the rear deck (which you will probably hear a lot too) I came across these speakers made by BSW which in my opinion sound BETTER than the factory premium speakers (i tested those too). You can visit their website and see for yourself the quality of their work and you can find pretty good deals on eBay too. If you're planning to install in your original rear deck housings, these will fit perfectly. Cheers!
      • e30owner
        • Feb 2016
        • 14
        That's the trouble. Many many options. For starters, how many watts do I get? I think the factory amp which I have puts out no more than about 8 watts RMS. Does that mean I should get speakers rated at no more than 40 watts, which is what I currently have?
        • isaac.delgado
          • Aug 2018
          • 8
          Those will work perfectly fine with your current head unit. If you want to really squeeze the juice out of them in the future you can get an aftermarket amp. Also try them with premium factory tweeters for full sound range.
          • e30owner
            • Feb 2016
            • 14
            What's the depth? My speakers are 2-5/8 inches deep.
            • isaac.delgado
              • Aug 2018
              • 8
              Same depth. They're a perfect fit for the factory deck housings.
              • reelizmpro
                • 9530
                If you have an aftermarket Alpine unit that's amplified (nearly all are these days) then you are using the built in amp on the headunit and not the factory premium sound amp. Either the factory amp is bypassed or new speaker wiring has been run. CDE-HD149BT is 50x4 W max.
                88 M3 - LACHSSILBER
                • e30owner
                  • Feb 2016
                  • 14
                  From what I can see on the bavsound website, they sell only complete upgrade kits, for cars no earlier than 1992, and they're not cheap.
                  • isaac.delgado
                    • Aug 2018
                    • 8
                    Check on eBay, they have pretty good deals on them. I remember I won mine in an auction for $32.
                    • e30owner
                      • Feb 2016
                      • 14
                      My install did not use the built-in amp on the head unit. The head unit is connected to the stock amplifier (using speaker-level outputs). I think that if I were to rewire the speakers, I would get a new outboard amp.
                      • Paul-Z
                        • Jan 2018
                        • 159
                        Are these only for the rear deck or also for the doors? What tweeters did you get?
                        • m5james
                          • Feb 2012
                          • 59
                          You honestly lucked out...the only "BSW" speakers on there now are a set of factory BMW speakers that someone put into BSW boxes
