Anyone know what this connection cover is called?
  • PhilB
    • 1
    I need a few of these. It says "AMP" on it, no numbers or any other marking. It was used to cover the connection between 2 non insulated single wire spade connections (male to female). It's 1.5 inches long, and when closed maybe .5 inches in diameter; white and plastic (or nylon or similar material).
    Anyone know? I've been googling for hours and can't locate it.
    Thank you.
  • uturn
    • Dec 2010
    • 1006
    Looks like an old style buss fuse holder.
    • george graves
      • 20003
      Hell -that might be OEM, or it might not be. How deep in the dash were you? It's been a while for me.
      I can recommend about 10 different connectors to replace that. If you insist on going OEm, then the REALOEM is your go-to source. That and the ETK will have you covered.
      (if you're restoring, you should already know those tools)
      Originally posted by Matt-B
