Window switch breaker wiring?
  • haaken675
    • Sep 2016
    • 601
    Hey everyone. I am in the process of building my car into a stripped out track/weekend car. I pulled a ton of wiring that isn’t necessary, and in my haste I believe I pulled out the window switch breaker wiring. I still have it thankfully, but I have no idea where it connects.
    Can anyone point me in the right direction?
  • ForcedFirebird
    • Feb 2007
    • 8300
    Will be two 90° female spade plugs. Some models had them in the button bank above the radio, some had them under the shifter console. Green wire with blue stripe.
    john@m20guru.com
    Links:
    • haaken675
      • Sep 2016
      • 601
      Yup, I still have that harness thankfully. I pulled it from the car entirely, so I don't really remember where it attaches to in the car. There is a power distribution block under the dash, and I have a feeling it plugs into that, but I don't know which one if it does. Even just knowing that would allow me to just wire in my own breaker as I really don't want to use the button and don't have a spot for it anymore either.
      • vpilarrt
        • Jun 2006
        • 2096
        One end goes to window switches, other end goes to terminal Q (center) in the C320 Acc Connector (near steering column on inside of firewall)
        • haaken675
          • Sep 2016
          • 601
          You my friend are awesome! I have searched and searched and searched and couldn’t find an answer: I was thinking I was going to have to jus treat all the connectors at this point.
          • george graves
            • 19992
            Download the PDF's - it's all easy peasy
            Originally posted by Matt-B
            • haaken675
              • Sep 2016
              • 601
              the pdf's don't show you which connector goes where physically...Trust me, I just spent a nearly a week pinning out and wiring a megasquirt harness to my m52 harness, I know how the diagrams work...
              • haaken675
                • Sep 2016
                • 601
                So after searching and searching and searching for a c320 connector, i figure dout that you must have meant c302. Now that i have figured that one out, i can clearly see where "Q" is. My question now is, where does the other plug end go? There is a second connector on the breaker switch wire and I am not sure where that one goes now.
                Thanks
                • george graves
                  • 19992
                  At the end of the PDF's there is about 10 pages that show the pin out of the connectors and there is a few "connector locations" pages as well. Some years/models are better than others, but it's all there! I'm not pulling your leg.
