Can the brake light switch be adjusted?
  • e30_mike
    • Apr 2018
    • 7
    I’m working on a manual swap in my 90 325i vert and i just swapped over the new pedals onto my assembly. The only problem is the new brake pedal is just missing the brake light switch, so my brake lights are always on. It’s seems like the manual brake pedal is a little thinner than the automatic one. Is there any way I can adjust the brake light switch?
    Also: I read that the brake light switch may be auto adjustable upon install? does this mean a new brake light switch could fix my issue?
  • reelizmpro
    • 9558
    It's true, remove the switch from your automatic, extend the plunger out with some pliers, then reinstall on the new pedal assembly. Make sure it's secured on the bracket.
    When you install it, the pedal will push the plunger in to the necessary length you need for the brake lights to come on when you push the pedal down. Also push the red plastic sleeve down into the switch to secure the tabs. I just found out about that myself a few years ago. Great design.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
