Sub Question
  • AndrewBird
    The Mad Scientist
    • 11898
    Sub Question
    This isn't car related, but it is audio related.
    I've got an Onkyo 230W powered 10" sub in a ~10x14x18 box (factory enclosure). My problem is when loud bass plays, the wind coming out of the port makes noise. I had the idea of putting something in the port (right now, I just stuffed a feather duster in there lol), which worked, it let some air out the port, but softened it as to not make noise.
    My question is, how will this affect the sound of the sub? If it won't hurt it, what do you guys suggest I put in it instead of the feather duster?
    Thanks.
  • StereoInstaller1
    GAS
    • 22679
    Butt plug?
    The noise you are dealing with is actually just from shitty design. This is why I use HUGE ports, which are generally stupid long.
    If you wanna fix it, double your port area and double your port length. So basically, if the port is a single 3" port, 9" long, do 2) 3" ports, 18" long.
    That right there is why the sub in my car is 2.5 cu.ft, with 20 4" ports that are 27" long. It is like a fucking habitrail in my box!
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • AndrewBird
      The Mad Scientist
      • 11898
      Just to update, when I first posted this thread, the sub was hooked up to a computer with a sub-output that I believe was not pre-amp. I now have the sub hooked up to my new receiver pre-amp output and it sounds AWESOME. There is still a little "wind" noise at higher bass levels with the other speakers turned down, but at normal volume, you can't hear anything but nice, clean bass.
      • smonkbmw
        Professor
        • Jun 2006
        • 4549
        haha i thought this had to do with home audio when i saw the onkyo title. chances are whatever enclosure it is in was made to spec for that driver.
