Car Alarm Removal/Wire issue
  • red325i
    • 137
    I'm removing an old Car alarm and so far I've only found 1 cut wire (rest have been spliced into).
    I need to know if the Black wire w/yellow stripe goes where they added a Red Wire. The Original wire and red wire both got to a relay. This wire is in a bundle of wires/plugs that are attached to the steering column. If anyone has an original glug that goes into that bundle I'd be willing to pay for shipping!
    The Red wire was added by the Alarm installer
    The Black Wire with Yellow stripe I think should go there?
    [IMG][/IMG]
    Here are both of them,
    [IMG][/IMG]
  • reelizmpro
    • 9556
    It's a starter kill relay so it should be fairly obvious what needs to happen. You need to bypass the relay so the car will start once it's removed. Isn't the other wire coming out of the connector Black/yellow also? Hard to tell from the pic. Anyway, cut the black/yellow wire at the yellow butt connector and install a female spade connector so that it can take place of the red wire.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
