Originally posted by BSAmarc
View Post
Yes, it's the premium sound....well, it has the trunk amp and separate tweeters so I suppose that's premium sound.
Do you know if anyone has ever made jumper wires at the amp to go between the input/outputs? If it the connectors have to be cut off in order to bypass, then I think rather than cutting them, I might buy a 4 channel amp and run RCA's from the head unit. That way I can leave the factory wiring alone. Do you happen to know what gauge power wire and size fuse is powering the factory amp? Could I use the factory power wire for a 4x75rms amp or something like that?
When you were talking about the passive crossovers being built in to the fronts, I don't think I'm following. Are you just saying to make sure I get speakers that come with a crossover?
Thanks for your help!!!
