My 318i audio lot of questions.
  • doucy2
    • Sep 2006
    • 1311
    Okay 91' 318i stock head unit, aftermarket front and rear speakers. I'm upgrading and need some pointers
    1 Does the stock head unit have a RCA output so i can run a amp in the trunk?
    2 Where is the stock amp in the car?
    3 Are there any writeups on wireing an aftermarket head unut?
    4 Does anyone make sub enclousures the fit in the back of the trunk and fit flush in there, leaving that clean look?
    cheers, I'm sure more question will arrise.
  • AndrewBird
    The Mad Scientist
    • 11898
    1. No. There are ways around this however. Luke should chime in on this.
    2. In the trunk near the antenna on the driver side inside fender if you have it. Only cars that came with premium sound had them. If you have tweeter pods next to your mirrors, you have premium sound.
    3. Search. This topic has been covered before. Basically you want to run all new wires and get rid of all the old wiring.
    4. Your best bet is to make your own enclosure. Yes, you can buy a box that will fit, but it won't be designed for your sub and your car and will end up sounding not as good as it could. It's not hard to make an enclosure. Basic wood working skills and a few tools. I'm sure someone would be willing to build you one for a small fee however if you really don't want to do it yourself.
    • doucy2
      • Sep 2006
      • 1311
      cool thanks I pulled the head out what a mess, I dont have premium sound so I dont have to mess with a stock amp. I guess i'll put in an aftermarket head unit.
      Where should I cut the wires are start rewiring from?
      • StereoInstaller1
        GAS
        • 22679
        If you look behind your left front speaker, you will fins a 4 connector Molex plug. You will see 2 yellow wires (with colored stripes) and 2 blue (also with stripes).
        Those are the rear speaker wires. Run 3 wires to the left (1 for the L/F speaker, 2 for the rear) and 1 to the right front.
        Connect to the rears there, brown stripes are negative.
        No factory deck (except a few Kia) ever came with RCA's, but there are other ways to feed signal into an amp. Go buy the cheap Sony from WalMart if you are desperate for cash...it is about $100, and has a sub level control.
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • So Live
          • 2512
          Luke
          Does that go for the premium sterio too?
          -Chris
          • StereoInstaller1
            GAS
            • 22679
            to the best of my memory, all e30s.
            Luke
            Closing SOON!
